polarizing generator
Old Apr 28, 2008 | 09:35 PM
58f100rat's Avatar
58f100rat
hey guys,i have a 58 f100,292.i took the generator off to paint the engine and generator,put it all back together,cranked it a few times over a few weeks.then battery was weak,had to jump start.got to thinking maybe i hooked the two wires on top of generator up wrong,swapped terminals ,did fine another few weeks,battery weak again.now i am wondering if anyone nows which wire goes where on top of generator,two wires come from regulator,and how to correctly polarize generator if i had it wrong.thanks. stony.
Old Apr 28, 2008 | 10:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
"F" to "F", "A" to "A". Terminals are marked at both ends, on the reg and gen. Do you have an ohmmeter or continuity tester?
Old Apr 28, 2008 | 11:28 PM
Bob at warsaw's Avatar
Bob at warsaw
Hi Ross
I also would like the information, yes I have
an ohmmeter. Is it done while the engine is
running or off? Must be off it onley the
ohmmeter is used
Old Apr 28, 2008 | 11:48 PM
Bob at warsaw
Is this also called flashing the regulator?
I always heard the engine had to be running?
But thats why I am asking questions
Old Apr 29, 2008 | 12:00 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I got this from mtflat awhile back;
Polarizing a Ford Generator
I can outline the procedure for polarizing the thing. With the engine off, at the regulator, remove the field (F) wire and briefly touch it to the batt (B) connection. You should see a small bluish spark. Re-connect the field wire and you're done. This is per the shop manual.
Do not use a jumper wire - you can cause damage.
Trouble for googling for the info, the older 3 brush gen's with a cutout use a different procedure for polarizing and you'll find a bunch of confusing info.
Bobby
Old May 2, 2008 | 08:59 PM
58f100rat's Avatar
58f100rat
thanks.bobby.that info helped and i did have the wires backwards.going to get all my new tires mounted and balanced tomorrow,get new park light lenses and then need to get insurance and register it.can't wait to drive it everyday.thanks again. stony
Old May 2, 2008 | 09:35 PM
Bob at warsaw
Stony
You are going have to show us some pictures
Take care
cadougherty_67
Jul 8, 2017 10:31 AM
F250Rob
Jan 18, 2017 11:21 AM
jvmcc
Sep 27, 2016 11:19 AM
F250Rob
20
Feb 18, 2016 08:05 PM
sciondude09
Mar 15, 2009 05:59 AM
