Well here's the set up..... Travis, (Strokin_Tatsch) Has bought my stage 1's out of my old truck No.3. This weekend was the time to do the change outs.
Keep in mind, I have 2 jobs, so the only time we get to do this is at night.....all night.
Friday, weld from daylight till 5pm. Go home, mow the yard and have dinner with the family. Everyone goes to bed, and I'm gonna get a head start by pulling the injectors from No.3. This is a 5 hour job for me if nobody bugs me. Well, no dice, it rains like hell before I can get to the shop. No problem, we have All night Saturday.
Saturday, wake up and actually get to spend the day with the family for a change and not weld. Finally everyone goes to bed and I get to start on No.3 about 10pm. Travis shows up to help. We pulled the stage 1's and reinstalled the stock injectors with new orings. We're driving it at 3am, we're good to go. However we know rain is coming.
Crossroad............ I ask Travis if he wants to continue on till the moring and get his injectors in. Of course he says yes, I would have too.
3:30am, I start taking his truck apart. Meanwhile he's cleaning and installing new orings on the stage 1's. About 4:30 it starts to sprinkle. No problem, I go get the canopy and we put it up over his truck. (I don't have a covered shop, just shop and ashpalt pad.) No problem, we're good to go now.
6:20am We are ready to install injectors, and we are about an hour behind because of a stuck glow plug. No injectors, glowplugs in the motor, it's wide open and it happens...............................
The wind picks up bringing hard rain. Travis is doing his best to hold the canopy down while I try to cover the motor. I litteraly throw all my tools on the ground along with the glow plugs and bolts to every thing. Throw the valvecovers loosly on there with rags under them. But the cowl is just pouring water in the drivers side head. (the rain is blowing under the canopy.) Screw it, I close the hood and we hold the canopy.................
Then the Hail hits, 1/2 inch hail. We can no longer stand the pain of the hail and the canopy is lifting us off the ground, and let go of the canopy and dive for the shop. An hour goes by and we check the damage.
Canopy was folded up like a beer can, and water obviously in the motor. At this point, we still want to try and finish. (Keep in mind, we've both been up for 26hrs at this point and now we are soaked and hungry.) I suck out the cyclinders quickly and we get 4 injectors in...Rains again.....suck out the other 4 and get the other 4 injectors in. Starts raining AGAIN. Finally, I called it and took Travis home about 9am. He had to be to work at 1pm and I had to be at work at 6pm. We both got very little sleep.
So when I get off tomorrow morning 6am, I will finish the install and flood the motor with oil and change it before startup and we should be good.
I thought for sure I could do 2 complete injector installs in one night but mother nature had other ideas. So I'll let yall know how it comes out. I'm assuming Travis has already gotten home from work and went to bed. I feel so bad for not getting it done for him because he has been so patient. But I bet we will look at the radar before doing 2 installs in one night. I tell ya guys, it was a rough night. And now I'm tired as hell at work right now. Anyway, I thought yall might like that story.
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
DP Tuner 2 pos. w/ custom switch
Hot Pedal
Gear Vendors OD
Good bye No.3 I'll miss you.
wow that is quite the rough night!! Just crank it over with the GP's out so none of that water/oil hydro the engine. change the oil and run it!! Any dents from the hail?
__________________ Tim 1997 F-350 CC 4x4 PSD Auto 260K
Tuned by Tony, Built by ME!, AD injectors, 6.0 IC, 17° HPOP, ESE Eliminator, 6" stacks, 4 Wh disc brakes
1/4 mile-14.59@88 MPH
Quote:
Originally Posted by Action4478
Most people come here for the facts ...not a hug ...
Wow, gotta love that TX weather...
Good luck on finishing!
__________________
1996 Ford F250 powerstroke diesel
Running 285/75 Bridgestone dueler revos
Gauges: boost, pyro, tranny.
15.6K ICP
140V IDM mod... easy as pie
6637, 3" downpipe to 3.5" turndown right after t-case. EGT's wont go over 1100, boost to 25 psi, sounds awesome!
I think i have AB code injectors!
Well, I went home and went to bed instead. I was cold this morning and I didn't want to deal with it. So I woke up early before work today and finished. Truck runs good, but I didn't drive it. I wanted to change the oil first. So Travis is headed to the shop to pick it up. I left all the stuff to change the oil for him. I'm anxious to see how he likes the new injectors. But so far so good.
Thanks for the rep guys. Tim I used my mity vac to suck out the cyclinders. Those weren't my concern. It was the water that went past there to the pan that I was concerned about. But I think we are in good shape.
__________________
RubberDuck
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
Hot Pedal
Gear Vendors OD
either one of you all got core you want to sell cheap??
__________________
i got a 97 model f-250. with a fuel pressure shim. no kitty or muffler. and it has a 3in. downpipe. and a tymar intake. and i am a member of BIG D's customs. go check out my pics at webshots here in my sig.
I don't have any that I'm willing to part with. I have one complete extra set. But those are staying tucked away in my go fast cabinet. And I'm pretty sure that Travis doesn't have any. Sorry brother.
__________________
RubberDuck
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
Hot Pedal
Gear Vendors OD
So, in your signature block, when you say, Goodbye no. 3 i'll miss you, is that referring to the truck?
__________________
15.6K ICP
yes secondary that is referring to his old blue dually.
Cody i was at matts sunday, and as soon as travis sat down he was passed out. sorry i didnt make it out. me and matt were putting a gooseneck in Mac's truck. and it was a long day for us as well so we went home and passed out.
__________________
The name's Austin, and i live in Austin, tx
MODS:
BTS transmission
Cales tunes
Kwik air filter mod
4 inch exhaust back to 6inch miters
Trans, pyro, boost gauges
Van turbo
T.E. SD Hpop
and a permagrin
all on a 1999.5, f350, 4x4
Yes, I'm talking about my blue truck. I love that truck. It almost killed me to take all the hotrod parts off of it. But I had to have room for the family, so I found my new truck after looking for 2 years. But that blue truck was built by me and all you guys here on FTE. When I bought it, I didn't know anything.
__________________
RubberDuck
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
Hot Pedal
Gear Vendors OD
