Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-19-2008, 01:25 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Stand-pipe question
looks like I'm going to build an Apple-Turnover. Supposedly drains better due to bowl shape on the top (bottom). Anyway thinking of installing a stand pipe as a precaution, how far should this go up? thanks
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 04-20-2008, 03:01 PM
Gun-Driver's Avatar
Gun-Driver Gun-Driver is offline
Garage is empty, add now
Gun-Driver is starting off with a positive reputation.
I guess that all depends on how big the tank is. (tall/wide)
I use a hot water tank to cook in but then I pump the bio while it’s still warm into a 55 gallon drum to settle in, that way I can start cooking another batch while the first one settles and my cooker stays clean.
I then let my bio settle for 12 hours or so before I pump the Bio off the top of the glycerol using a 3/4 ‘ pipe attached with a hose to my pump, I stop pumping just before reaching the glycerin. (This way I make sure there’s no glycerol in the Bio).
I pump the settled Bio to my methanol recovery condenser tank and recover the methanol before cleaning with magnesol in another drum set up with a mixer.
I then drain the glycerol out of the bottom of the tank and pour it in a drum to save until I have around 30 to 40 gallons then I recover the methanol from that.
  #3 (permalink)
Old 04-21-2008, 10:00 AM
Rushmore X's Avatar
2003 Ford Excursion
that sounds like a good idea. Just trying to get by with fewer tanks due to limeited space. I think a cone bottom tank would be easy to use if I went thtat route. thanks
__________________
Tags
60, apple, biodiesel, standpipe, truck, turnover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
