How's your Bed to Cab fit like on your F-150's
I have an 08' F-150 and the fit of the bed to cab is off a little on the driver side everything lines up otherwise so if I moved the bed over it would be off so thats out of the question. Back window is perfect with bed so dont see what is wrong or would need adjusting. Passenger side bed to cab is perfect, driver side it's like 1/4 inch off from spot on with bed. Noticed when looking down the sides of the truck from the rear looking towards the front the cab sticks out a bit but the passenger side it plush. I was drying the truck f and was running a towel down the side and it dipped in and gave a closer look and noticed this. Also looked at alot of the F-150's on a dealers lot and several have this poor fit as well and all were on the driver's side. Some were perfect others were off more then mine.
Ya but if i do that then it will be not centered with cab. I talking about the sides bed to cab, if i look from behind lining up tailgate to back window it's perfect then I look at the sides and passenger side bed to cab seems ok but drivers side bed to cab seems like it could be better. dont know.
hey Steelhorse, are you hypochondriatic?
exhaust, bed, cab, axle...all this stuff doesn't line up
I'm trying to visialize what you're saying in post #4, but I just can't. Are you talking about how far the bed sticks out in comparison to the cab?
take a ruler and lay it across the bed and cab. 1/2 on each. does it lay flat on each side of the truck, or does it get "cocked" and not sit flatly?
as for adjustments, you can move the cab maybe 1/16 to 1/8" of an inch. there isn't much play. the bed can be adjust quite liberally though.
if not, I appologize. I surf 3 different forums and sometimes get confused
I think the exhaust was Ryan50hrl (the mod)...The axle, cab, bed, cowling, and some other aches and pains is Steelehorse though.
