How's your Bed to Cab fit like on your F-150's
I have an 08' F-150 and the fit of the bed to cab is off a little on the driver side everything lines up otherwise so if I moved the bed over it would be off so thats out of the question. Back window is perfect with bed so dont see what is wrong or would need adjusting. Passenger side bed to cab is perfect, driver side it's like 1/4 inch off from spot on with bed. Noticed when looking down the sides of the truck from the rear looking towards the front the cab sticks out a bit but the passenger side it plush. I was drying the truck f and was running a towel down the side and it dipped in and gave a closer look and noticed this. Also looked at alot of the F-150's on a dealers lot and several have this poor fit as well and all were on the driver's side. Some were perfect others were off more then mine.
I never thought it but just checked mine and they close enough to even as to not be noticed.
Loosen your bed bolts and adjust the bed until you are happy with the alignment of it, easiest quickest way to do it. Save yourself a trip to the dealer where they probably won't fix it to satisfaction anyways.
Originally Posted by rollerstud98
(Post 6051874)
hey Steelhorse, are you hypochondriatic? :-kneeslap
exhaust, bed, cab, axle...all this stuff doesn't line up :confused: I'm trying to visialize what you're saying in post #4, but I just can't. Are you talking about how far the bed sticks out in comparison to the cab? take a ruler and lay it across the bed and cab. 1/2 on each. does it lay flat on each side of the truck, or does it get "cocked" and not sit flatly? as for adjustments, you can move the cab maybe 1/16 to 1/8" of an inch. there isn't much play. the bed can be adjust quite liberally though. |
Originally Posted by tylus
(Post 6057943)
exhaust, bed, cab, axle...all this stuff doesn't line up :confused: . |
(Post 6057943)
(Post 6057943)
So the alignment of the box looks good -- just not the box side on the drivers side? I would guess that maybe your box side is sprung a bit causing it to bow out up front? -or- Maybe that box side was 1/4 of an inch out of alignment when it was being welded in place.
Darn robots! T. J. |
Ya like was mentioned above, almost unnoticable but can tell still. I had a bedliner sprayed in maybe it happened then, who knows. dealer lot there's alot like this on XL's and XLT's but on the upgraded packeages like Lariat, etc. looks really good.
Originally Posted by SteelHorse08
(Post 6058469)
Also what were you talking about exhaust ,axle, bed to cab and ya did this emblem as well:confused: what is this that you dont understand?
if not, I appologize. I surf 3 different forums and sometimes get confused |
(Post 6063018)
weren't you the guy with the misaligned axle, and the exhaust that isn't hanging right?
(Post 6063018)
if not, I appologize. I surf 3 different forums and sometimes get confused tylus... you may be surfing too much..ha ha:-bigparty |
well, 2 are for the F-150, and the 3rd is for the Durango
Tylus, now look at yours at drivers side on the lower panel of bed to cab notice how it's goes inward some vs. the passenger side is straight on? I was looking at your gallery and the pic. that shows the driver side looks exactly like mine, so maybe normal after all, dont know.
