97 psd trouble starting
I have a 1997 ford psd that is giving me a little trouble. Every once in a while I it will crank normally and hit but not start. After that I can crank until the cows come home and it will not start. If I shut it off and retry it will start fine, but I ge a check engine light. I had a local auto parts store do a scan and got the following codes.
P1391 glow plug circuit low input (bank 1)
P1393 glow plug circuit low input (bank 2)
does this just mean I have bad glowplugs in cylinder 1 and 2 or is this something else.
Thanks in advance for any help.
The problem is not in cylinders 1 and 2. The problem would be there is not enough current going to bank 1 and 2. Are the batteries charged fully? I would try to let the GP's warm a bit longer before I started it. If it hits and doesn't start, turn ignition off and back on and let GP's warm for about a minute to a minute and a half then start.
Post back and give results of this.
Gooseguy84
1999 to 2016 Super Duty
06-15-2012 12:14 PM
Krazymaan
06-13-2011 10:19 PM
