fuel level prob
on
I I fill very slowly toward the end of a fillup, I can get a few extra liters in there and it can cause the gauge to read 1/4 past full, so I think that part is notmal. The problem of stalling at 1/4 to empty however, is not normal. You most likely have a broken fuel pickup line in the tank. I've read there is also a return line with a rubber valve at the fuel sender that can cause fuel to enter from higher up on the fuel sender and produce similar symptoms. Either way, you are likely looking at dropping the tank fo find the problem.
Whats the most you ever put in the tank by the time it starts starving for fuel?
Tom Bowser
03-06-2011 08:58 PM
LFDavidson
04-16-2010 04:02 AM
neumanc
09-19-2003 12:43 PM
