Can I level 2001 F350 by lowering back ?
Hi All,
I am such an anxious, new F350 owner - I am posting and I dont even have the truck yet. Purchased the other day a 2001, std cab, 7.3 diesel, 125,000 mi, auto off EBAY recently. Unfortunately, the truck build date is 08/00 (which supposedly has the infamous "mech diode" in the tranny) - but no tranny work to-date and no signs of trouble yet. Anyhow, the truck slopes forward ... and I want to level it. But, I dont want to be lifting the front. Why cant I lower the back ? I've read ... maybe I can have some sort of thinner spacer block (from F250) swapped in ... would this work ? Any reason why I wouldnt want to do this ?
Thanks in advance, Brian
Yep, you can use a F-250 rear block and u-bolts.
I did it with my 07 F-350.
If you haul heavy loads or tow heavy you'll want to run load-assist air bags to prevent it from sagging with the load.
I love the setup now since it's lower to load heavy stuff in the bed and I just have to air up the bags to keep it slightly higher in the rear end.
I lowered my 2006 F350 srw 4X4 using the f250 rear blocks and also bought the u-bolts from the ford dealer when I ordered the blocks. All the parts came to a little over $100. I did it to level my 5th wheel. Now I have take-off shudder when the trailer is on. The 3000 lb pin weight puts the drive shaft out of true and causes a shudder. I am going to add air bags to correct that problem.
