2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Driver's Seat Feels Loose
Old 03-17-2008, 02:14 PM
AmericaRocks's Avatar
AmericaRocks
AmericaRocks is offline
I have an 07 Expy EL and the driver's seat feels loose. When I first accelerate, it feels like the seat "settles" back a little. Anyone else seen this issue?
I wanted to have them look at this when I take it in for the two recalls that I got notice of last week. I am also having a brake squeaking issue that is intermittent and (of course) will not happen when I have the truck at the dealer (I've had them look at it twice).
Thanks in advance for any information,
John
Old 03-17-2008, 03:03 PM
berry1234's Avatar
berry1234
berry1234 is offline
Try moving the seat up a hair or back a hair. I would tell the dealer. Shouldn't shift while driving.
Old 03-17-2008, 05:43 PM
IQ9's Avatar
IQ9
IQ9 is offline
I had this problem when I bought my 2003.5 G35 sedan. Man, Infiniti/Nissan fixed and fixed and fixed the problem until they were out of ideas...OH...and it still does it every once in a blue moon. I hope Ford can fix it once and get the job done.
Old 03-18-2008, 07:17 AM
rjd75's Avatar
rjd75
rjd75 is offline
I have noticed mine rocks ever so slightly forward or backward on occassion.. moving it does nothing to help. I have not bothered mentioning it to the dealer as I think it will be impossible to reproduce the problem as most of the time it sits still..
-R.
Old 03-18-2008, 08:52 AM
AmericaRocks
-R.
That is basically where I am. I have noticed it since I got the truck in July, but it hasn't been bad enough for me to go through the hassle of trying to get the dealer to check it. It seems like it might be getting a little worse. I just wanted to see if this was a know problem or if it was supposed to have a little "give" to it.
Old 03-18-2008, 10:39 AM
CarbonClear's Avatar
CarbonClear
CarbonClear is offline
I had the same problem in my 07 Expy as well. I took it into the dealer for them to take a look at it. They ended up replacing the rack system under the seat. You may want them to do the same. So far the seat is working great
Old 03-22-2008, 10:25 PM
cjgeorge32's Avatar
cjgeorge32
cjgeorge32 is offline
WHAT A COINCIDENCEI have about 8,000 miles on my 07. Just today I felt the front seat rock when I accelerated..When I move back and forth I can still feel it…. Not enough to bring it up with the dealer…
Old 04-03-2008, 04:47 PM
function12's Avatar
function12
function12 is offline
My seat tracks were just replaced. Same problems as above.
Old 04-03-2008, 05:12 PM
berry1234's Avatar
berry1234
Does your seat also sorta of grind a bit as it gets to the end of the track? Not so smooth.
Old 09-12-2014, 09:52 AM
CHIEFSOU's Avatar
CHIEFSOU
CHIEFSOU is offline
I know this is an old post, just FYI on possible seat FIX
https://www.ford-trucks.com/forums/1...-seat-fix.html
Old 10-02-2014, 04:29 PM
harleypete's Avatar
harleypete
harleypete is offline
Thanks Jim the pics were great that should that problem
After contacting you I check the passenger side and the strangest thing
Is that both seat slide back and in center position you half way on the track
Got any advice for this problem ? If not you were a great help with drivers seat
Thanks
AGrayson84
1997-2006 Expedition & Navigator
29
06-27-2019 10:53 AM
bigdave8629
2015 - 2020 F150
08-11-2016 11:05 PM
BocceMon
01-21-2016 01:31 PM
CHIEFSOU
10-02-2014 05:23 PM
Jmatthews
06-20-2013 01:23 PM
Quick Reply: Driver's Seat Feels Loose
