Driver's Seat Feels Loose
I have an 07 Expy EL and the driver's seat feels loose. When I first accelerate, it feels like the seat "settles" back a little. Anyone else seen this issue?
I wanted to have them look at this when I take it in for the two recalls that I got notice of last week. I am also having a brake squeaking issue that is intermittent and (of course) will not happen when I have the truck at the dealer (I've had them look at it twice). Thanks in advance for any information, John |
Try moving the seat up a hair or back a hair. I would tell the dealer. Shouldn't shift while driving.
I had this problem when I bought my 2003.5 G35 sedan. Man, Infiniti/Nissan fixed and fixed and fixed the problem until they were out of ideas...OH...and it still does it every once in a blue moon. I hope Ford can fix it once and get the job done.
I have noticed mine rocks ever so slightly forward or backward on occassion.. moving it does nothing to help. I have not bothered mentioning it to the dealer as I think it will be impossible to reproduce the problem as most of the time it sits still..
-R. |
-R. |
I had the same problem in my 07 Expy as well. I took it into the dealer for them to take a look at it. They ended up replacing the rack system under the seat. You may want them to do the same. So far the seat is working great
WHAT A COINCIDENCEI have about 8,000 miles on my 07. Just today I felt the front seat rock when I accelerated..When I move back and forth I can still feel it…. Not enough to bring it up with the dealer…
My seat tracks were just replaced. Same problems as above.
Does your seat also sorta of grind a bit as it gets to the end of the track? Not so smooth.
I know this is an old post, just FYI on possible seat FIX
Thanks Jim the pics were great that should that problem
After contacting you I check the passenger side and the strangest thing Is that both seat slide back and in center position you half way on the track Got any advice for this problem ? If not you were a great help with drivers seat Thanks |
