351m valve springs
351m valve springs
fastredford,
My Ford books list installed height spec for the 351M/400 valve springs as 1.820" and solid height spec as 1.33". That would allow a maximum valve opening of 0.490".
Some '78-'79 M-blocks had a shorter exhaust valve spring with installed height of 1.68" and solid height of 1.20". Those springs would allow a maximum exhaust valve opening of 0.480".
If you're going to change the cam, I recommend changing the valve springs (and retainers, seals, etc.) too. If your existing valve springs have seen a lot of use, they could be too weak to keep up with a good new cam.
BubbaF250
1980 F250 4x4 Custom, 351M/NP435/NP208/D44HD-TTB/D60-FF/3.55s 6750 GVW, Rust & White.
BubbaF250
79sparky
07-15-2012 03:14 PM
AstroFab
09-08-2011 04:33 PM
wilevel2
01-13-2007 03:05 AM
78SupercabPowerstroke
10-28-2002 01:34 PM
