Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 03-16-2008, 10:30 AM
schmitty65 schmitty65 is offline
Garage is empty, add now
schmitty65 is starting off with a positive reputation.
Question headers
i have a 65 f100 2wd with a 351m and c6 also have installed powersteering but am having trouble figuring out what headers will work and get past steering box and clear crossmember any help is appreciated
  #2 (permalink)
Old 03-16-2008, 11:10 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK Pro-Street/StateTK is offline
Pro-Street/StateTK is gaining momentum as a positive member of FTE.
Schmitty
Welcome to (FTE)!
You will need to buy your headers for 73-79 the frames on these trucks are
the same up front! I have not install any headers on the 351m/400 ! But you
search some of the old posts you should turn up a lot. When you search
keep in mind you will be looking for info on headers for 65-66,67-72,73-79, so
you may want to check out posts in those forums also!
P.s. heres a link to my gallery take a look at the crossmember that I modded.
http://www.ford-trucks.com/user_gall...=79912&width=2
Wally Womack
__________________
"Failure is an opportunity to begin again more intelligently" Henry Ford
My Pro-Street Article
  #3 (permalink)
Old 03-16-2008, 11:46 AM
rusbukt rusbukt is offline
rusbukt is starting off with a positive reputation.
Was curious as to which steering box you have? Bendix or Saginaw?
I am running a Bendix and had to tweek one of the pipe's a bit to get it to clear the box.
I know it is no-no to "dent" the header. But at the time.??
  #4 (permalink)
Old 03-17-2008, 12:35 AM
Rusbukt
I really dont think theres nothing wrong with having to dimple one of the tubes, as long as you use the side of a big socket and tap it easy a little at
a time, the headers will still flow very good.
P.S. now on a set of headers that are ( TUNED ) I would really try not to
dent them, if you dont need to!
Wally Womack
__________________
  #5 (permalink)
Old 04-12-2008, 07:36 AM
heavy d460 heavy d460 is offline
heavy d460 is starting off with a positive reputation.
I have a 61 merc on a 63 frame (unibody). I was having the same issues with headers and steering. I have a 460/c6 combo in the truck.
What I found that worked best is a set of hooker headers from 88-94, they fit very tight to the engine, and the drivers side runs almost under the tranny. I did not have to heat and bend any thing, and there is all kinds of room.
Hope this helps a little, don't be scared too try headers from other years of trucks, all demensions and measurement are available on line for most quality headers
  #6 (permalink)
Old 04-12-2008, 10:39 AM
daveengelson daveengelson is online now
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Don't believe you will be able to install headers w/ a Bendix box. If recall, Sanderson Headers will make to fit.
Sanderson Headers - Custom Built Headers
Have a 390 in one of my 65's with Hedman long tubes, and another 65 with a 302 and using Hooker long tubes. Only issue was on passenger side crossmember, had to remove minimal amount of material to increase flange clearance. Also, had to lift engine slightly, and if recall, remove starter to install. Used Hedman offset extentions to get around the tranny crossmember issue. Intend going with Pro-Streets model when I replace mufflers, which should be soon, way too loud.
__________________
'problem with engaging in useless activity is never knowing when your done'
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.(Daily Driver)
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
64 Pontiac Tempest w/ GTO package(currently in numerous boxes)
dave
  #7 (permalink)
Old 04-12-2008, 10:54 PM
billy12360 billy12360 is offline
1963 Ford F-100
billy12360 is gaining momentum as a positive member of FTE.billy12360 is gaining momentum as a positive member of FTE.
i was hoping you had the y-block in your truck... i was going to say reds headers..i ordered a set from them... and the drivers side clears everything...
the only problem i had with the company was... the fact that they sent me to driver sides... i called them up and they are sending me a new one back...
__________________
1963 ford f-100 with 292 Y block 2 barrel carb. headers ran into 2 1/4th pipes, connected to cherry bomb turbo mufflers elec. fuel pump.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
