302 boss performance mod suggestions
Boss 302? As in the '69-70 4 bolt mains, Cleveland type heads?
Or 302 HO?
Or the "new" Boss block in 302 config?
Torque and hp cheap are mostly available to those with wheezer 302s. 302's that came from the factory in Boss 302 trim, or even HO trim, already have the easy stuff done.
So what exactly do you have? 2bbl, 4bbl, variable venturi, efi?
Or 302 HO?
it has 4 bolt mains, 8 bolt valve covers, screw in freeze plugs and EFI. the guy that had the truck before me used to run empty semi trailers back across state lines with it. when i got it i just thought it was a regular 302 but it has all the carachteristics that people describe as the mustang boss. from what im guessing it is a 302 boss. im not sure what it has for heads on it either
Some numbers here at the top of the sb forums threads:
https://www.ford-trucks.com/forums/3...6-10-06-a.html
on
Originally Posted by 4x2mudder
i would like some performance suggestions that will give me optimum horsepower and torque
ive thought about getting my hands on a 460 or a 351, and selling this motor. which at this point i dont know what it is. if i get a 460 or a 351 then ill be able to pull a real trailer. ive thought about making it a stroker too. i was thinking something more like maybe a performance cam, or dual quads instead of EFI
335clevo
04-12-2002 09:43 PM
