Competition Diesel racing, sleds, dynos, power tuning and max performance.
Best DOT rated pull tires
Old 03-05-2008, 09:02 AM
scottie2hottie's Avatar
scottie2hottie
scottie2hottie is offline
Question Best DOT rated pull tires
What is the best tire for the pull track? I can't imagine boggers are the best since they are specifically designed for sloppy mud, but that's what I've been running. Have been thinking about buying a set specifically for pulling. Thanks for input.
Old 03-08-2008, 08:00 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,392 Likes on 2,089 Posts
Most guys around here use Cooper Discoverers or BFG AT tires
Old 03-08-2008, 07:19 PM
97 HD's Avatar
97 HD
97 HD is offline
Same arround here
Old 03-16-2008, 10:38 PM
duramaximizer's Avatar
duramaximizer
duramaximizer is offline
BFG's AT's, Mickey Tompson Baja Claws, TrXus STS, Cooper makes some decent ones.
Not in any order and track conditions and tire pressures make the biggest differences.
They will all hook up and break stuff so be ready. Wider and taller is "generally" better if you can maintain your optimal gear to minimize downshifting at the end of the track.
Don't run mud terrains. They dig and pile dirt in front of the sled and make it harder to pull.
Correct tire pressure is key.
Old 03-17-2008, 09:09 AM
scottie2hottie
truck ill be pullin with is a 4 spd, so i don't think it'll be down shifting
Thanks for your input.
Old 03-17-2008, 07:03 PM
duramaximizer
Oh and try to keep the sled from hitting ya in the rear. LOL
Old 03-17-2008, 07:20 PM
scottie2hottie
easy pal.......LOL
Montync
66
03-21-2017 05:13 PM
JohnnyPol
1997 - 2003 F150
03-05-2017 08:59 PM
redman84
02-23-2017 11:40 PM
sixseven
2015 - 2020 F150
13
03-11-2016 01:52 PM
GeneLaw1
1999 to 2016 Super Duty
42
02-07-2014 11:44 AM
Quick Reply: Best DOT rated pull tires
