Plastic Interior Trim Repair
Either this hasn't been specifically covered or I'm just not using the right search terminology. What is the best thing to repair broken plastic interior pieces? Specifically I need to fix my driver's side A pillar trim that is broken off at the lower screw. PVC cement, a jb weld product, epoxy, something else?
Subscribed. I can tell you what WON'T work. It's a binary epoxy called PC-7. Works great on metals (I've repaired three rusted fuel filler necks with it), and hardens REAL hard. Similar to JB-Weld. I tried it on the hinge cover for the jump seat / console on our 40/20/40 seat. Fitted the pieces together and slatherd the stuff on the back side of the work. It hardened up real nice, but just didn't stick to the plastic.
PVC cement probably won't work, because, well, it's not PVC. It's probably ABS or PS or something. There should be a symbol somewhere on the back side of the part indicating the material. But I don't think I've ever seen PVC used as interior trim material.
Awesome, thanks Mike!
Doesn't work well on plastics that will be flexed in use, but filling a gap, crack or seam with baking soda, then soaking it with superglue works well. Or, where the superglue isn't setting up because there is too much gap, or you want a 'filler bead', you can sprinkle/pour baking soda into the fluid superglue, and it will set up hard.
Not pretty though.
Not pretty though.
Haha that makes way more sense. Yeah I've found a few on there but would like to give repair a try before shelling out the eBay jack.
That would be the coolest. Ruby red. Driver's side A pillar.
Daytona F1
51
11-15-2012 07:55 PM
