2006 escape steering wheel
ok any one know how to remove the steering wheel on 2006 escape to get to cruise control switches and is there a self test you can do for cruise control functions like holding on button while you turn ign switch on as in other models ??? any help would be appriciated
ok i found in other forum how to do a cruise control self test switches on wheel a little finniky but got it to do test after it was done cruise light flashed 3 times according to chart this is problem
3 Brake Deactivation Circuitry Brake pressure control
valve defective circuitry
now where do i go from here where are these items as there is no valve on my master cylinder that i can see help........
Take the trim off the steering wheel itself and the steering column. That will allow you to see the four small hard steel bolts that hold the steering wheel on. I found it easier to to turn the wheel 1/2 turn to move bottom bolts to the top. When your done, the Cruise switches are held in place by very small screws. The Ford dealer will sell both switches and the harness in one kit. I don't know what the switches cost is because I bought my Escape used and repairing a broken cruise switch was part of the purchase agreement. The used car dealer purchased the switches for me.
jasondinsmoore
1999 to 2016 Super Duty
22
01-07-2019 06:16 PM
