rear drum brakes on a 1996 f350 PSD
This just started a couple weeks ago, but my brakes felt fine going foward and reverse and the parking even worked, but I was plowing a couple weeks ago and while backing up the left rear brake locked up without hitting the pedal. I pull foward and it is fine for a little whilke then when backing up it locks up again?
Well yesterday I was pushing the snow pile's back for this new snow coming, and it locked up and then BANG it freed up? and now I have a soft pedal and going down the road the ABS is chattering like mad, the parking break still works fine? any ideas?
on
well you will definately need to pull the drums off. I would do it with wheel cylinders, hardware kit, adjuster kits and brake shoes all sitting beside you. More than likely you have some springs that are broken or you have the fiction material that has come off the brake shoe and getting wedged in there.
TJ sounds right on.
I plowed w the diesel for the first few weeks this year but it sucks so much more fuel dollars than my '99 SD w 4.30's and discs in the rear.
Anyhoo... I noticed the rear adjusters must have taken every last little bit of slack out and they would give a chirp or squeak as I stopped in reverse. But ohhhh the power...
Back to the thread - I think the adjusters do their thing on the reverse travel and at the end of the braking action? But once tight I think they stop ratcheting tighter?
As TK said tho... Get everything. Brakes have a tough life down in there. Put it all in new and you will be happy you did. Nothing like new clean parts - fresh, un-rusted bleeders are cheap too. Have fun...
Have fun he says!
Now that you mention it - I just got this truck on the road last fall and that was one of the things on my list to check. Well... it has them stock aluminum alloys and BEAT and BEAT and BEAT to get them things off the rear hubs with the full floater. A big chunk of fire wood and the splitting maul.
You talk about fun! Swinging the sledge on your side in the gravel...
No one ever accused my Mom of raisin' any bright chil'ren
need more than a sledge Hammer
Originally Posted by okfarrier
Ford should have included a sledge and block with the tire tools.The first time you get caught changing a flat out on the road the sledge gets a new home in toolbox.
OH also to the one who said they plowed first time this year with their diesel. I put that bully dog 6 position chip in mine, and well on highway I get close to 20MPG, I have 2 tanks I think one is a 17 and one is a 18? but I filled the front one (18) up back in December, and I still have 1/4 tank left. Plowing only locally, 3 driveways within 1.5 miles. and we had like 6-8 major storms up here in Tug Hill NY < Like I said above right now we have like 3 foot of snow on the ground, but back a month ago we lost a good couple feet.. My Diesel I feel dows very well on fuel.. now can't say the same with rear brakes though.
You will find that, over time you will get more and more brake pedal travel, before you get braking effect, as the mastercylinder's travel/fluid is being used up just to open the rear shoes. Can be dangerous.
Or... you will have to be adjusting them open/tighter fairly regularly. For me - it ain't gonna happen as I don't have that kind of time.
on
its very doubtful that the self adjuster made the shoes come apart. Age, wear, heat and quality of the lining play into the life of the lining. The self adjuster hardly are self anything. They rarely keep the brakes where they should. You will have no problems with what you did as long as you still manually adjust them though.
velcro7279
12-19-2005 07:38 PM
