GEM Mod Question
Old 06-02-2012, 11:08 PM
cekkk's Avatar
cekkk
cekkk is offline
GEM Mod Question
When I take the key out of the ignition and leave my '02 F350D, electrical things just keep right on working. Like the radio,all the stuff that should shut down. If I lock the doors with the lock/unlock button, the driver's door lock unlocks itself after a few seconds. If I've got the headlamps set over to auto turnon at dusk, come dark the lights will turn on.
I'm thinking this is the gem mod. Right? And easy to get to of course, right in the middle of the dash I'm told. Over four hours labor.
I was told this problem was caused by a faulty windshield seal that allowed water to run down through the firewall and over time, ruin the mod. Anybody heard this? So is there a Ford bulletin on it?
Old 06-03-2012, 06:58 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Common "leaky windshield syndrome", sounds like.
On an F150, the GEM module is above the fuse box, upper left side under dash. Severe cases may require replacement of both the GEM module and the fuse box, in addition to repairing the windshield leak.
On the F-SuperDuty, the comparable functions are controlled by the VSM (no GEM module). It's up under the dash as you described.
JOE-Lambert
1999 to 2016 Super Duty
09-26-2018 04:14 PM
freightliner009
09-25-2016 09:20 AM
Randy5556
04-08-2009 05:59 PM
gjoseph
1997 - 2003 F150
01-27-2005 10:34 PM
blitz10
1997-2006 Expedition & Navigator
02-21-2003 08:30 PM
Quick Reply: GEM Mod Question
