vacuum diagram
vacuum diagram
I have a 79 F-250 with a 400 does anyone have a vacuum diagram for this. I mainly want to know where the vacuum line from the distributor should go to, mine curently goes to the manifold vacuum but I was told that the vacuum line from the air cleaner should go there,
Thanks
Joe
Thanks
Joe
vacuum diagram
Well, you're opening a whole can of worms. If you're trying to pass smog, especially in CA, you're gonna need the whole diagram. If not, then the line in to the distributor should be hooked up to carburetor vacuum, for the vac advance while accelerating. Any other questions, I need all your trucks info. Federal or CA truck, man or auto, etc. Good luck.
Crewcab Turbo
06-08-2011 08:19 PM
MitchD
25
01-06-2011 03:27 PM
