Whining Sound
You probably already know, but -
P0341 CMP Sensor Circuit Performance (Camshaft Position Sensor Circuit A)
Possible problems - Poor connection, Bad Sensor, Electrical noise
P2290 - Injector Control Pressure too low<O</O
I wouldn't think that these would be related at all to the turbo.
High Pressure Oil Pump (HPOP) perhaps?
http://dan.prxy.org/Truck/6L_bible_h.../Page_042.html
Do you have any oil leaks?
The HPOP is driven off of the rear gear train. An "Accoustic Wave Attenuation" fitting is installed to dampen hydraulic noise. A noise from the HPOP could change pitch w/ engine speed I would guess. You also have the low ICP. These are just my guesses - hopefully someone more experienced will come along. Since you are out of warranty, this could be fairly expensive if it were the problem. Hope you get a quick (and cheap) answer.
You might find some useful information in this area...
Workshop Manual
2004 F-Super Duty 250-550/Excursion
Workshop Manual
i too have this problem. the truck has 150k on it. the only thing is i cant hear the whining/whistle until i drive it and get the rpms up really hard in 2-3 gear.
it too sounds like its coming from the turbo. maybe mines different though.
is it possible my 4" downpipe has come loose a bit?
