I almost hate to even bring it up but...
I just calculated mt mpg at 14.3 the truck is an 07 screw 4x4 5.4 3.55gears mostly hwgh miles and I kept it under 70 all the time. Does that sound about right? Ohh btw the truck only has 9k mi on it maybe break in? Anything really help intake chip whatever?
on
The Supercrew is 500+ lbs heavier than then Supercab so its not a valid comparison. Check the tire inflation, especially now with colder weather (every 10 degrees can deflate the tire by up to 1psi) --- good chance mileage is being lost to that, and the odometer error due to this only makes the calculation worse.
My 04 screw 5.4L 3.73LS 4x4 has gotten as good as 19.1 on the highway at 65-70 around 2000 rpm. Sounds a little low. That was with the truck 100% stock. Will have a better idea this weekend on what to expect mileage wise with the 3" leveling kit installed last weekend and the 305/65/18 BFG AT that got installed today.
Unfortunately, an intake won't help nor will one matched with an exhaust. See this post: https://www.ford-trucks.com/forums/6...g-results.html
I just got an Edge programmer so I'll be reporting results on that in the near future...just as soon as I stop having fun with it.
I have a 2006 F150 Screw with the 5.4L, 4x4, 3.55LS. I took a trip to Virginia Beach and back last week. I averaged 15.6 mpg running 70 to 75 mph. Of course in Georgia I had some slower speeds do to the construction but not much.
Basically if we were looking for good gas mileage in my opinion we should have bought something else than the F150 4x4 Screw.
I love the truck but gas mileage sucks...
Is that a fact about the winter blend fuel? My Dad has told me they put additives in the winter fuel that causes a loss of MPG. My truck has sufferend a loss of 2MPG and I can't for the life of me figure it out. I never noticed a change in past winters, it's always remained pretty consistent.
Yes, you will lose fuel economy with the winter blends of gas. Also, this winter has been colder then the previous, so your load on the engine is greater which also robs f.e. sp maybe that's why you're noticing more this year. Sucks all round.
btw- on my 04, 5.4, 4x4, 3.73s I get 14-15 mpg. I have never seen 16+ as some of the other users have stated.
