Transmission Swap C6 TO AOD
Good Afternoon All
I'm looking to put an AOD on my 78 Ford Truck with a 351M in it. It originally had a C6 in it and it finally is going to need to be rebuilt so i decided to look into an AOD for it. I hear that I need an adapter kit for it. Where can I get this from? What else should I know before doing this?
1978 Ford Truck
2WD Short bed
F150 351M
Thanks
William
1978 Ford Truck
2WD Short bed
F150 351M
Thanks
William
http://www.transmissioncenter.net/
Here is a link to one. Kind of spendy. Also, remember the AOD tranny was made for the 302s. So even a 351M may be too much for the AOD and without some upgrades, it might burn out in a short period of time, unless you drive pretty carefully.
Take my advice, I have a lot of experience with AOD/Es.... Having owned a modded turbocoupe, and knocking a few out..... They can barely handle FACTORY power, let alone more. Just going from 6-17psi of boost on a factory IHI turbo on a TC (TINY turbo) is enough to knock one out. One AOD I had in a TC had only 60k factory miles on it, and it had been babied, and the fluid/filter done every 20k, and it died at 70k miles. I had a SN95 mustang 302 with headers, full engine back catless exhaust, jet chip, and some ignition work that was preparing to do one in.... The C6 can handle a pretty large amount of power. Rebuild it, or get another one, they are a dime a dozen man.
Originally Posted by Witty73
E40D is a much better tranny than the A.
quick question. i only have a 302, but was thinking of putting an AOD behind it. i have a c4 currently and was hoping the AOD would be a better choice for fuel economy. not really worried about power dont plan on doing any towing. always thought the aod was a better tranny, but from what you guys are saying that is not the case. and not that i think it is going to matter much but have 3.5 gears.
what do you think?
what do you think?
