'85 460 tough to start, idles rough until warm, throttle lag
Hi Folks, new guy here. Hope to be here a while I just bought an '85 F250 Explorer with the 460, and I'm having a series of problems that I'm pretty sure are all related. I'm not at all experienced with these motors (I mostly know small-engine imports from the 90's and early 00's), so I think I need some help. I'm seeing three symptoms:
- It can be very difficult to start. I will crank it for 3-5 15-second stints, sometimes pumping the gas, sometimes not (just trying everything I can think of), and it will eventually start. But once it does start...
- It runs very rough. It sounds like it's about to die (very low idle speed), and if I give it any gas, it actually will die. Once it has been running for a couple minutes, I can very slowly give it just a little gas and it will gradually speed up to what sounds more like a reasonable idle speed. After about 10 minutes, it sounds fine, like it doesn't have a problem at all. Although, it seems not to modulate it's idle speed on it's own. Without throttle input, it would never alter from it's initial low idle.
- Once it is running and warm, it acts exactly as I would hope, with one minor issue: If I'm stopped or nearly stopped and I hit the gas too abruptly, the engine will hesitate. The harder I stab the gas, the worse the hesitation, killing the engine if I just jam it. If I give it 1/8 throttle for a second first, waiting until I hear the engine respond briefly, I can hit the gas as hard as I want after that, and it responds perfectly.
driller tom
01-11-2010 12:46 PM
