'96 F350 Add-a-leaf kit
Old 02-09-2008, 12:10 PM
BigD7575's Avatar
BigD7575
BigD7575 is offline
Hey guys i was jus wondering if anybody knew of a add-a-leaf kit for my '96 F350 standard cab long bed? Any help would be appreciated. thanx
Old 02-09-2008, 12:35 PM
IceboxFX's Avatar
IceboxFX
IceboxFX is offline
i have a 250 and put a skyjacker add a leaf in my truck. i'm sure they make them for 350's too.
Old 02-09-2008, 04:28 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
I bought mine off ebay. Rough country for around $80 plus shipping.
Old 02-09-2008, 04:40 PM
884x4broncoII's Avatar
884x4broncoII
884x4broncoII is offline
how much harsher does the add a leafs make it ride?
Old 02-09-2008, 05:39 PM
2 stroke man's Avatar
2 stroke man
2 stroke man is offline
i just put em on mine for $95. not too much harsher of a ride. you wouldnt know it if u didnt ride in the truck alot
Old 02-10-2008, 07:29 AM
fordman837000's Avatar
fordman837000
fordman837000 is offline
are we talking about front or rear add a leafs? I am looking for a front one to help with the weight of the plow in the winter. I just bought a rear set and have air bags on top of that in the back.
Old 02-10-2008, 07:32 AM
2 stroke man
we are talking front. mines rough country
Old 02-10-2008, 02:22 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Fronts for me as well.
Old 02-10-2008, 04:25 PM
fordman837000
hey tj or 2 stroke man do you guys like your add a leafs? Front end doesn ' t sag yet just want extra help in the front end.
Old 02-10-2008, 06:36 PM
2 stroke man
i'm lovin it! (tm mc donalds)
Old 02-10-2008, 06:47 PM
WALJON's Avatar
WALJON
WALJON is offline
Hey fordman I have a set of firestone air bags in my front end and they work awesome for if you have a plow I added a leaf in the back for the weight of my camper and trailer in the summer but still doesn't seem to be enough so I am contemplating air bags in the back as well this way with no load I can let the air out and have a decent ride
Old 02-10-2008, 06:48 PM
FARM69's Avatar
FARM69
FARM69 is offline
You guys have any links as to the right set of add-a-leafs to get for the 250. Also, how hard is install? I'm assuming it probably depends on how rusty things are.
Old 02-10-2008, 07:09 PM
97-psd's Avatar
97-psd
97-psd is offline
http://cgi.ebay.com/ebaymotors/80-98-Ford-F-250-F-350-2-Leveling-Lift-Kit_W0QQcmdZViewItemQQcategoryZ33585QQihZ015QQitem Z250214476925QQtcZphoto
this is where I will be getting mine once I get my bumper and winch mounted, these should fit a 250 and 350 and are meant for diesel trucks. They seem pretty straight forward and simple to install, un-bolt u-bolts, lift truck, install levelling springs, lower truck, re-install u-bolts, and ta-da!! but it is probably not as easy as it looks.
Old 02-10-2008, 07:48 PM
Robbgt's Avatar
Robbgt
Robbgt is offline
Got mine from a place in Brockton, Ma called Wood-Ward spring. They tweaked them a bit on the machine a bit to give them a little more U-shape. Cost 68 bucks.
-Robb
Old 02-10-2008, 08:08 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
I liked mine. On the 250 you will need an alignment after you installed them. I was just able to get camber back into spec with new camber bushings. One problem I had with my 250 was that after the leveling kit it was too level. It was still 1/2 to 3/4 lower in the front but when I would park in certain spots it looked like my truck was sagging in the rear. So of course I had to lift the rear a bit!
Quick Reply: '96 F350 Add-a-leaf kit
