code 1211
code 1211
hi guys im new to the webpage but ive got a 97 f250 with a superchips programmer on it but recently my check engine light comes on and pops up a code 1211 but it will also do it when its set back to stock what should i do? Any help would be nice
Check the fuel pressure also .....
This is from the manual:
X7 KOER ON-DEMAND DIAGNOSTIC TROUBLE CODE (DTC) P1211
- DTC P1211 indicates that injection control pressure was above or below commanded desired pressure during self test mode.
- Possible causes:
- incorrect oil or viscosity
- poor oil quality
- gel fuel/no fuel
- low fuel pressure
- damaged IPR valve
- high-pressure oil system leak
- damaged high-pressure oil pump
- damaged PCM
- Verify correct oil quality/viscosity and correct fuel grade are being used for the temperature conditions.
Yes Im Sure Rotella 10w-40
I cannot recall 10/40 diesel rated
http://www.shell.com/home/Framework?..._products.html
Bill
