code 1211
Old Feb 9, 2008 | 10:36 AM
stroker85's Avatar
stroker85
code 1211
hi guys im new to the webpage but ive got a 97 f250 with a superchips programmer on it but recently my check engine light comes on and pops up a code 1211 but it will also do it when its set back to stock what should i do? Any help would be nice
Old Feb 9, 2008 | 10:44 AM
Action4478's Avatar
Action4478
Welcome to FTE ... If you are getting on it and get the light ...It may only mean the HPOP can't keep up with demand ,,, It sets the light if pressure is not what was expected for 7 seconds ...Does it run poorly at the CEL ?...You may also be low on oil or in need of an oil change ....
Check the fuel pressure also .....
Old Feb 9, 2008 | 10:46 AM
Action4478's Avatar
Action4478
This is from the manual:
X7 KOER ON-DEMAND DIAGNOSTIC TROUBLE CODE (DTC) P1211
  • DTC P1211 indicates that injection control pressure was above or below commanded desired pressure during self test mode.
  • Possible causes:
    • incorrect oil or viscosity
    • poor oil quality
    • gel fuel/no fuel
    • low fuel pressure
    • damaged IPR valve
    • high-pressure oil system leak
    • damaged high-pressure oil pump
    • damaged PCM
  • Verify correct oil quality/viscosity and correct fuel grade are being used for the temperature conditions.
Is oil and fuel quality OK?
Old Feb 9, 2008 | 10:47 AM
stroker85's Avatar
stroker85
well i just changed the oil in it like 3 days ago so i know its got oil but yeah it seems like it does it when i kinda get on it
Old Feb 9, 2008 | 11:02 AM
kawa's Avatar
kawa
Stroker, 2X welcome,
What oil are you using and what part of the country are you in??
Rog
Old Feb 9, 2008 | 11:09 AM
stroker85's Avatar
stroker85
Rotella 10-40 Im In The U.S Kentucky
Old Feb 9, 2008 | 12:04 PM
stroker85's Avatar
stroker85
Where Can I Find The IPC Censor?
Old Feb 9, 2008 | 12:57 PM
Action4478's Avatar
Action4478
Pic....here...
Old Feb 9, 2008 | 02:07 PM
MADVAN's Avatar
MADVAN
Are you shure Rotella 10/40?
Bill
Old Feb 9, 2008 | 06:44 PM
stroker85's Avatar
stroker85
Yes Im Sure Rotella 10w-40
Bill
Old Feb 9, 2008 | 06:47 PM
2 stroke man's Avatar
2 stroke man
what part of KY?
Old Feb 9, 2008 | 06:51 PM
MADVAN's Avatar
MADVAN
Iam just not shure you used the right oil.
I cannot recall 10/40 diesel rated
http://www.shell.com/home/Framework?..._products.html
Bill
pdx02
Jan 23, 2008 12:51 PM
sfgiantsfan9
Nov 23, 2007 10:19 PM
brettwingfield
Sep 16, 2007 09:14 PM
chevyhater74
1983 - 2012 Ranger & B-Series
Jun 26, 2007 01:10 PM
