Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
  #1 (permalink)
Old 02-09-2008, 01:22 AM
XolieX's Avatar
XolieX XolieX is offline
Garage is empty, add now
XolieX is starting off with a positive reputation.
supercrew f150 top rear seat removal!!!
i am a new owner of a 06 supercrew king ranch! i need to transfer my audio stuff from my sport trac to my f150. i looked online on a few sites and people are mostly putting the amps behind the seat where they can't been seen.
does anybody have an idea how the backseat comes out?
anybody have pics of they're 150 with amps installed on them?
  #2 (permalink)
Old 02-09-2008, 01:11 PM
canstacker canstacker is offline
canstacker is starting off with a positive reputation.
Pics:
http://www.ford-trucks.com/forums/63...eir-seat.html?
rear seat removal:
highlight=screw+rear+seat+removal#post5002708
http://www.ford-trucks.com/forums/59...r+seat+removal
Some where on here there are detailed pics of seat removal...do a seach.
  #3 (permalink)
Old 02-09-2008, 11:13 PM
XolieX's Avatar
thanks that helps alot however the rearseat removal part seems kinda hard to do! i wish it showed other pics further back to see better.
does anybody know how to take out the front bezel to replace the radio? i will be putting back in my pioneer avic-d3 shortly.
i also notice that the front speakers are easily accessible with just prying of the grill. i tried to do the same with the back and seemed like i was going to damage something if i went harder. do i have to take off the whole panel or do i just need to pry the grill off like the top?
does the back door have a spot for a tweeter like the front?
  #4 (permalink)
Old 02-09-2008, 11:51 PM
deisele75's Avatar
deisele75 deisele75 is offline
deisele75 is starting off with a positive reputation.
Yes. you have to take the door panel off. But it's pretty easy. Takes about 10min per side. Do a search and you will find instructions.
I have my AMPS behind my seat. There are pics in my gallery.
__________________
This is sad...http://www.classiccarsrotting.com/
  #5 (permalink)
Old 02-09-2008, 11:56 PM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
2005 Ford F-150
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
Idunthave1yet
Try this for the rear seat removal... http://www.ford-trucks.com/article/i...2008_F150.html
It seems to be easier for me to grab a hold to one of the tabs toward the bottom of the bezel (by the ashtray opening) and firmly pull back evenly.
Its a piece of cake once you notice the metal clips (which are the only thing holding it on). Also, once you get most of it off- start to pay attention to the harnesses which are attached. Some folks have managed to weasel the bezel off to one side and still change the radio out without removing the harnesses, but I like to make sure everything is tucked firmly in ty-wrapped since I have a few more extra components in there.
...Prior to putting the bezel back on, you may want to see if any of the metal clips came out with the bezel. IMHO- it was easier to re-seat the bezel with the clips put back into the dash-( before putting the bezel on).
The back panel will have to be removed for speaker change/additions. Also, I don't recall ever having tweeters in the rear doors (factory) in all the 150s I've played with.
__________________
-Rich; SC-DPS Reserve Trooper
'05 ReCab XL Pw,pwdlk, cruise & more w/139K
Chapters / 2004-2010 F150 / 2011 F100 Moderator
  #6 (permalink)
Old 02-10-2008, 12:45 AM
XolieX's Avatar
diesel thats a nice install, however i'm going to try to install memphis PR 4.100 4 channel and a memphis PR 500.1 mono channel in the same place as you. then later down the road install center channels and buy the smallest possible amp and put it under the seat or something!
  #7 (permalink)
Old 02-10-2008, 12:06 PM
deisele75's Avatar
I actually still had some room back there. You could probably fit 3 amps.
__________________
  #8 (permalink)
Old 02-10-2008, 03:39 PM
Sonicman's Avatar
Sonicman Sonicman is offline
Sonicman is starting off with a positive reputation.
Check out my gallery as well. I have 2 amps behind the back seat. I also bought a sub box for 2 JL audio 10"subs from www.supercrewsound.com The box fits perfectly under my back seat. Tell me what you think. I put my system in my self so feel free to ask questions. The guys on this site gave my all the info I needed to put in everything.
  #9 (permalink)
Old 02-11-2008, 02:54 AM
XolieX's Avatar
sonic that looks awesome man! are you really happy with what supercrewsound gave you? i have 3 10w1's right now and i'm contemplating if i should just buy his box and put 2 of my 10's in there or just sell all these 3 subs and use JL audio's stealth ported box!
the JL dealers around here say that ported box are the way to go but its bigger. he said with the f150 stealth box, its with a w3 and its freakin awesom and say it'll out perform 2 10w1's in a sealed box.
let me know your thoughts on this!
  #10 (permalink)
Old 02-13-2008, 09:19 AM
Sonicman's Avatar
I am happy with the supercrew sound box. It looks like it is supposed to be there. This is my first system so I can't compare my sound to anything else. But if I where you I would go by the the JL guys suggestion. I talked around with guys in my area and got a different suggestion from all of them so I went with what I thought best.
  #11 (permalink)
Old 02-27-2008, 06:38 PM
XolieX's Avatar
today was my quest to get that back seat out and it pissed me off for quite a while because i couldn't get my hand beaters back there to reach for anything.
i just kept in mind to look for a square hole! well i wasn't sure if i was on it and i pushed hard and did a bicep curl on the seat and it came up! did the other side and boom, out!
thanks for the help guys.
to add in, it looks like i can fit my small 4 channel mtx back there on the driver side! just enough space for it and still have some slash on the wires on the bottom. the harness on the keyless entry won't come out unless the amp is moved though.
i'll post pics whenever i get them back in! i'm sure it'll look nice.
also,
Tags
06, 150, 2007, 2008, back, center, f150, ford, front, raised, rear, removal, remove, seat, supercrew
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
