banks' turbo?
I did find some more info:
http://store.bankspower.com/Categori...3-d6a52b9c73f3
Quick-Turbo® assembly
Banks developed the Quick-Turbo in conjunction with the Holset turbocharger and Cummins Engine companies, to eliminate sluggishness "out of the hole" and produce strong acceleration. Quick-Turbo produces massive torque right from idle, achieves a higher peak faster, maintains more boost through the powerband, and doesn't over-boost. Banks' exclusive BigHead® wastegate actuator prevents "wastegate blow-open" by keeping the valve seated at higher pressures, increasing mid-range torque and top-end power. Banks corrects boost-level limits in late '99.5-2003 models with a high-boost compressor wheel, built for higher boost levels without compromising turbo performance.
Originally Posted by Mike Norwood
sorry i wasn't as clear in my question as i could have been. i am wondering how the banks turbo compares to some of the other turbos out there such as the H2E or the TN BB
thanks for the info Curtis. btw who sells the H2E and/or the TN BB?
many thanks guys. the reason i'm asking all the questions is i rolled my truck about six weeks ago. however, it looks like i will be able to rebuild it since the frame sustained no damage whatsoever. while i am rebuilding it i am going to try to get most of my mods done while i have the cab off.
BTW, if you don't mind telling us, how did you roll the truck? I hope that you are alright.
Originally Posted by Pocket
Yep, it's just a Wicked Wheel, actuator, and 1.0 A/R turbine housing. You can pick up those parts for much cheaper elsewhere than Banks, and get the exact same performance and quality.
