Gas tanks
Gas tanks
85 to 87 carbed F-Series used the larger diameter pickups/senders without the sender mounted fuel injection pump.
Hmmm, you said Bronco. It probably needs a Bronco specific sender to reach the bottom of the tank properly. So - find a carbed donor Bronco.
FYI, various data implies the Bronco could have had either the small or big sender for several years after the F-series went to all big senders. I don't know what options controlled the Bronco sender size.
Ludis
Ludis
