1970 351 Cleveland
1970 351 Cleveland
I just bought a "70" 351 C on ebay that was rebuilt about 8 years ago but never used. I have taken it down to relube and to see just what I have.
4v closed chamber heads
new flat top piston
hyd lifters
My question is: the cam. It's new, there is no mfg name on it, the only ID info I can find on it is, it has an NB on the space between the last lobe and the rear bearing guide and it has a 10 between the last two lobes, and it also has a yellow paint strip over the NB area.
Any ideas? I looked all over the internet and come up with nothing.
new flat top piston
hyd lifters
If I had to guess. I'd say those markings are nothing more than casting identification numbers for the core. Without the cam card all you can do is put it in straight up, 0 on the chain. Even if you degree it in you would have no idea where it's supposed to be in at. I'd probably just go buy the cam I want.
87beater
18
04-23-2024 08:37 PM
Polkat
11-11-2005 07:30 PM
