I had this happen once and nothing I did would get the heat to come on and it was cold outside. I ended up turning truck off then back on and it worked. Anyone knows what causes this?
Seems to happen on the diesel trucks. I had an 04 with a 6.0L and it would blank out every now and then. The next time I started the engine it would come back. I've read where some have cycled the headlamp switch and got ti work again. It's pretty common.
turn on your headlights - it'll trip the sticking 'non replaceable' relay on the back of the instrument cluster and wake up all the things in power-save mode.
