'92 Ford explorer burning oil?
Old 01-25-2008, 09:28 AM
blakrodder33's Avatar
blakrodder33
blakrodder33 is offline
Exclamation '92 Ford explorer burning oil?
I just bought a '92 ford explorer and gave it a tune up. I only put about 400 miles on it and I am putting the second qt. of oil in it. I haven't seen any leaks at all and it isn't puffing out blue smoke. I heard I should Check the spark plug from cylinder #5 for crusty deposits. Apparently the lower intake manifold gasket has a habit of leaking oil into that cylinder. Any body have any other ideas before I tear into this thing?
Old 01-25-2008, 09:59 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Check the plugs and do a compression test, Post results
Old 01-25-2008, 10:14 AM
mrshorty's Avatar
mrshorty
mrshorty is offline
this is a fairly common problem on the OHV. Usually it can be fixed by simply torquing the lower intake manifold bolts back up to spec. I remember the first time I did this, they were pretty loose. It can be done without taking anything off, though many like to remove the upper intake. Before you tear it all apart, I would suggest just grabbing a torque wrench and a 10mm and 13mm socket and see if the bolts are just loose.
Old 01-25-2008, 01:02 PM
blakrodder33
I already did a compression test and everything was fine
Old 01-25-2008, 01:03 PM
blakrodder33
I did torque down the intake it was a little loose but not too bad i'll see how that works.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
01-06-2015 01:51 AM
njtinman2
10-08-2006 09:40 PM
mack316u
16
11-27-2004 12:13 AM
RnROutlaw
01-21-2004 07:16 PM
boris
01-16-2003 05:55 AM
Quick Reply: '92 Ford explorer burning oil?
