1996 F250 Parking Brake
Received 3,186 Likes
on
on
You dont have to pull axles like the older ones. (pre 84?) Just adjusting your rear brakes will probably fix the parking brake and give you a better pedal. Never a bad idea to check them though.
Parking brake adjustment
Tore into my 96 F350 extra-cab rear brakes hoping to adjust shoes and resolve parking brake issue.
Upon drums removal found both rears of shoes cracked in half yet still like new linings.
Drums good with no lip. Put new shoes on hoping it would resolve the issue with some adjusting, no luck. Adjusted them all the way to rubbing (very difficult to get right with large tires). Got to the job and stink in the air as soon as I stepped out of the truck. Adjusted a tad too tight so backed them (pass side) off till the truck rolled a little. Happened 3 more times, again only right side, where I had noticed upon installation the adjuster wheel wasn't really engaging arm. Initially thought it was for the wrong side but upon closer inspection the "R" was stamped on it so left it. Couldn't see any reason it wouldn't engage as I double, triple checked all springs & cables ensuring unobstructed assembly. Still almost no parking brake! Searched all cables front to back for adjuster but none to be found??? Could my cables be stretched? Side-note my old shoes as well as new shoes are identical (primary & secondary) in size. I always thought the primary linings were shorter?
strange pattern on front lining
Mrhollywood82
05-23-2017 12:03 PM
bigandblack
04-27-2017 06:15 AM
parcher440
10-06-2016 12:35 AM
