Hazard Lights/E40D?
Hazard Lights/E40D?
"To everyone that has a 90's or newer Ford with the E4od transmission.
DO NOT Run your truck with the HAZARD lights on.
By doing so will cook your transmission.
The torque converter lock up solenoid is controlled by your brake lights. Every time they flash they switch the solenoid on/off.
By doing that it ends up destroying your transmission !
Just an FYI for you Ford owners."
This was posted on another forum that I read. Wondering if there is any truth to this?
Originally Posted by c00nhunterjoe
yeah, that would definatly justify a huge recall on fords part.
It IS true. I was there when this was fixed.
What happened is that the torque covnerter unlocks with the brake lights. In the early E4ODs the PCM would see the four way flashers as a brake application. The PCM was just looking at the change in voltage on the brake light circuit and couldn't tell the difference.
The fix was in the calibration. The PCM was calibrated to ignore the brake light circuit once the TPS read more than 10% pedal.
on
1 Post
Originally Posted by MADVAN
It works off the 3rd brake light.
No effect at all with the hazz on.
Bill
Bill
Another issue on old trucks with the flasher is that it would pulse trailer brakes too. But when the thrid brake light was added, but the transmission and the trailer brake enable both came from the third brake light circuit and neither pulse when the flashers are on.
About when was it changed (year).
If you run your hazz lamps the 3rd brake light will not flash with the lower(hazz). The load is not the same 4ways vs brakes.
This is TRUE for 1995 and 96 models. its tied into the same cicuit. I had a 95 dually that was this way and my dads 96 was this way. My current 96 is this way as well. i noticed it when I had some trailer issues and tuned them on at about 45 mph and noticed it DID unlcok the TC. I dont know if a manual lcokup switch would get you around this or not.
on
1 Post
Here is the schematic from the '95 shop manual (click for big):
The torque converter locks in dirve or overdirve when the throttle is depressed and the brake is off. It also locks in first or second if the revs are over 2200 RPM and the throttle is above 3/4 after a time delay - brake on or not BTW.
Nope, it kicks it into limp mode with hazard lights. Drive down the road in OD, click your hazards on and watch your RPMs, they WILL jump. It doesnt show it in this diagram, but it is wired in. I cant remember who posted it, or where they found it.
Do a forum search, youll find it. It was hatched out about a year or so ago on here before.
