Cold weather ?
on
Originally Posted by c00nhunterjoe
wont get to operating temp when its in the 30's or even 40's. wont hurt anything but your mileage
on
Mine won't get to temp at idle either. Pretty hard to heat an engine at idle with egt's sometimes drop to 200 degree's. I don't think my injectors have anything to do with it either. They are operating on stock injector programming. The biggest thing with these trucks is one, The stock temp gauge is junk! It will never read accurate since you have no idea if the 0 or the M or the N is operating temp. And two the stock stat is too cold anyway! with the stock 195 stat my truck would not break 180 no matter what I was doing with the truck. Now once warmed up it stays a rock solid 200 unless it idles.
on
even though its a cummins, my buddys truck does what coons does... we drove it to the coast the other day, and its in about the 40's here, but it would warm up to about 190deg (on his stock guage) and then the thermostat would open, take in all the cold water from the radiator, then go down to about 130deg and thermostat would close and it would warm back up to operating temp, and do that again.. whole way...
mine does basicly what the cummins does, i have good heat on the highway, the t-stat is only a couple months old, and the truck did the same thing on the old stat as the new, i replaced it when the water pump bearing died. my stat is not stuck and my coolant is good. i just cant keep the heat in the motor when its cold outside. at idle it wont even get to full temp like it does in the summertime. but it runs cooler on the highway. i havent paid any attention to what it does while towing in the winter. next chance i get i will have to pay attention
maybe for poops and giggles try the cardboard thing ,Iuse a full cover from ford it works very well ,them semi's you see with the covers closed all the way are looking for trouble I know from experience,those trucks are designed around the turbo and inter cooler set up your trucks turbo was not designed for the inter cooler set up therefore I think you will be ok with covering it up all the way unless of course you are pulling something ,tinted plexiglass would look good I bet
