Electric water pump or underdrive pulleys?
Old 12-28-2007, 01:37 PM
SuperDuty73's Avatar
SuperDuty73
SuperDuty73 is offline
Question Electric water pump or underdrive pulleys?
What should i go with either an electric water pump or underdrive pullys? I have a 2001 5.4L supercrew with hedman headers, accel ignition, Magnaflow metalcore cats, cherrybomb dual exhaust, electric fans, predator tuner, performance products 75mm throttle body, MAC cold air intake, and throttle body spacer.
How much does each item help, which is better and how much more MPG will i get doing either of the two?
Thanks
Old 12-28-2007, 03:15 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Well if you go with an E. water pump you will also have to go with Efans, ditching the stock fan and going with Efans will give you a little mileage, I doubt an electric water pump or UD pulleys will however.
Old 12-28-2007, 04:28 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
skip down a few posts and read the comments from the kid that wants to get 25 MPG from his truck----- put your money in your pocket and be happy with the truck, if you want better milage, buy a pinto.
Old 12-29-2007, 12:39 PM
superdutymj's Avatar
superdutymj
superdutymj is offline
like steve said, save your money. The lackluster power numbers you might gain and the possibility of gaining 1-2mpg isn't worth all the money you'll spend on the go-fast goodies.
Old 12-29-2007, 09:32 PM
jdhudall's Avatar
jdhudall
jdhudall is offline
They both will only gain you about 5-8 hp but the underdrive pulleys are about $140 and e-waterpump is about $225! If the manufacture claims 15-20hp increase figure 5-10hp I have always test every part on the dyno before and after installation and they always are about 10 hp off from there claims.
Old 12-30-2007, 05:40 PM
superdutymj
They're claims always seem to be made under the ideal situations and who knows what else they did while the truck was on the dyno. I usually just stick to the basics when i modify anything for power. Exhaust, Intake, and chip if I get the other two balanced out.
DJ Kontakt
33
11-08-2016 07:07 PM
Bmccord03
08-11-2015 08:01 AM
wileec
1978 - 1996 Big Bronco
10-20-2003 06:54 PM
95xltmud
06-28-2002 06:50 PM
Syzle
05-10-2002 02:50 PM
Quick Reply: Electric water pump or underdrive pulleys?
