Just a thought ..... If we place each sensor in a water tight plastic box and mount each one some where in the frame near the tires. Will it work that way???
I don't understand why everyone is strapping the sensors with bands and straps. I have the sensors in my wheels. I put my nephews wheels on my truck and for got to swap sensors. When I got home I took my sensors off my wheels and put them away to use when I get new tires next year or so. The sensors should just pop right back on with no problems. I just went out and tried it and they will clip right back on. If you look at the sensor there is a brown or tan plastic clip on one end of the sensor. Take a small flat screwdriver and on one end of the clip move it towards the middle and it should pop out then you have to take the screwdriver and where the plastic piece was you will see and silver piece of the band. You just push that forward and pull the sensor away and it should pop right off. Hope this helps.
my 04 expedition, senors are crap, i fixed a couple times i am not fixing them anymore, the dealer said he wouldn't turn the sensor off because of liability.
#1 why are you in the 04-08 F-150 forum with an Expy problem
#2 Put tape over the light on the dash if you aren't going to fix them
#3 See the other thread you dug up
