Haven't been on here in quite awhile. But just wanted to let you guys know if you didn't already. I just purchased a 2008 F-150 and I had some 2007 sensors from my old tires and put them inside my 22's. According to my manual the 2008 now comes with a sensor resetting tool. None of the dealers here ever heard of it but they read it in the manual and had to give me one. I reset the sensors and have not had one problem with the sensor warning light coming on again. It also said in the manual if you did not receieve one to go to you dealer and they will provide one to you.
Can you post a pick of the sensor tool? Or a part number. The tire shop that did mine has a nice, expensive, aftermarket tool to retrain sensors. Good for Ford to pony up and provide one of these. Typical of the dealer not knowing anything about it.
Here is the pic of the tool given by Ford. There is also a pic in the manual. Just follow instructions in the manual to enter the system and place the remote on the sidewall of the tire and press the button. Takes all of about 45 seconds to do the whole process.
I took 5 minute epoxy and glued them in exactly 180 degrees from the valve stem like the manual says, and then used the thick police type tie wraps to double secure it. obviously you put a couple of them together so it is long enough. Never had one move and we have done a bunch of them.
We have had them move on Mustangs from the guys always burning out. Hope this helps
I have a 2004 f150 fx4 and am getting 20 kmc xd monster rims. Should I buy the after market sensors or take them off my stock rims. Also Will that tool for your 07 work for my 04
I had a 2004 F-150 and I don't remember having sensors in my tires. But if you do I would use the ones you have since they match that computer. I don't know if the tool would work, but if I was to guess since I used my 2008 tool with the 2007 sensors, my guess would be that it would work.
