How to disable the lock-up torque converter..
Old 12-25-2007, 09:59 AM
nofortunateson's Avatar
nofortunateson
nofortunateson is offline
in a 1991 AOD 5.0L. I think the lock-up converter is malfuntioning and I would like to disable it to see if the problem I am experiencing goes away. I believe there is a trans temp sensor that keeps the lock-up from working until the trans temp gets to at least 100 degrees. How would I unhook this sensor? Is it inside the trans? Is it fused? Thanks.
Old 12-25-2007, 09:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
That's a mechanical lockup. There is no electrical signal. You probably could find a way to disable it with a complete trans teardown and some modifications. There's no way to trick it.
If it were a '92 or newer AODE it would be easy to do.
dirtsnow
16
01-18-2018 08:46 PM
rivermobster
12-05-2015 12:12 PM
Beastlyforddude
16
02-16-2011 01:52 PM
dylan8427
12-16-2010 05:47 PM
jimjoebob99
17
05-13-2010 06:43 AM
Quick Reply: How to disable the lock-up torque converter..
