Remove factory radio 07 f-150
Old 12-24-2007, 06:01 PM
Dannel's Avatar
Dannel
Dannel is offline
Thumbs up Remove factory radio 07 f-150
I have a Kenwood DDX6019 NAV system and i am wanting to install it myself i was wandering if anyone could tell me how to remove my factory radio easily??? any info would be greatly appreciated...
Old 12-24-2007, 06:59 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
Open ash tray, grab trim, pull. Pull real hard.
Old 12-24-2007, 09:14 PM
Brolli's Avatar
Brolli
Brolli is offline
yup. you will start to think that your going to break it, then at that point pull harder and it will unsnap itself. remove the four screws and unplug the radio. just as easy as that.
Old 12-24-2007, 09:43 PM
Dannel's Avatar
Dannel
Dannel is offline
Thumbs up thanks and another question
thanks guys for the info i appreciate it...ill probably have more questions as the project progresses...oh yeah i remembered one....is it possible to use my factory sirius antenna with the new reciever if i get a kenwood adapter
Old 12-24-2007, 10:00 PM
black04lariat's Avatar
black04lariat
black04lariat is offline
I think I recall reading somewhere that if you can if you get the plastic casing off the factory plug, it should reveal the same type of small round metal connector like the aftermarket ones use.
Old 12-24-2007, 10:30 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
I used the factory satellite antenna for my aftermarket system. Like black04lariat said, you just have to take the plastic casing/adapter off.
Old 12-25-2007, 08:55 PM
wreedZ71's Avatar
wreedZ71
wreedZ71 is offline
How do you remove the ashtray?
Old 12-25-2007, 10:07 PM
black04lariat
If you have the console shifter, pop the radio bezel off first then remove the 2 screws that hold the ashtray in.
Old 12-25-2007, 10:10 PM
wreedZ71's Avatar
wreedZ71
wreedZ71 is offline
if you drop something behind teh ashtray is it gone or can you retreive it?
Old 12-25-2007, 10:20 PM
black04lariat
You can reach your hand down behind it.
Old 12-25-2007, 10:26 PM
wreedZ71's Avatar
wreedZ71
wreedZ71 is offline
ok so i need to pull the wood trim off first then that will expose screws?
Old 12-25-2007, 10:44 PM
black04lariat
Yes. It has clips that run along the sides of it (be sure to get all the clips out before you try and re-install the bezel...you will see what I mean when you pop it off). You need to pop the radio bezel off, unplug plugs and set aside, then it will expose two 9/32 (7mm) screws that hold the ashtray in. Remove them and the ashtray comes out.
Also, you can pop off the cupholder bezel that goes around the console shifter by opening the console lid and just pulling up and that will give you more access too, if I remember correctly.
Old 12-25-2007, 10:47 PM
wreedZ71's Avatar
wreedZ71
wreedZ71 is offline
do you know of a downloadable service manual for these trucks? I know i have downlaoded a 2000+ page one for my dodge. it told you everything from torque specs to how to remove the radio.
Old 12-26-2007, 12:31 AM
Dannel's Avatar
Dannel
Dannel is offline
thanks guys for all the help
v860rich
04-03-2016 12:02 AM
Matt M, PA
02-13-2016 09:35 AM
Pmustian
1999 to 2016 Super Duty
09-04-2014 03:59 PM
madsonp
09-11-2012 02:03 AM
wrumiel
07-16-2009 08:38 AM
Quick Reply: Remove factory radio 07 f-150
