Remove factory radio 07 f-150
I have a Kenwood DDX6019 NAV system and i am wanting to install it myself i was wandering if anyone could tell me how to remove my factory radio easily??? any info would be greatly appreciated...
Open ash tray, grab trim, pull. Pull real hard.
yup. you will start to think that your going to break it, then at that point pull harder and it will unsnap itself. remove the four screws and unplug the radio. just as easy as that.
thanks and another question
thanks guys for the info i appreciate it...ill probably have more questions as the project progresses...oh yeah i remembered one....is it possible to use my factory sirius antenna with the new reciever if i get a kenwood adapter
I think I recall reading somewhere that if you can if you get the plastic casing off the factory plug, it should reveal the same type of small round metal connector like the aftermarket ones use.
I used the factory satellite antenna for my aftermarket system. Like black04lariat said, you just have to take the plastic casing/adapter off.
How do you remove the ashtray?
if you drop something behind teh ashtray is it gone or can you retreive it?
You can reach your hand down behind it.
ok so i need to pull the wood trim off first then that will expose screws?
Also, you can pop off the cupholder bezel that goes around the console shifter by opening the console lid and just pulling up and that will give you more access too, if I remember correctly. |
do you know of a downloadable service manual for these trucks? I know i have downlaoded a 2000+ page one for my dodge. it told you everything from torque specs to how to remove the radio.
thanks guys for all the help
