Soule46
You were refering making an 8BA look like a 59A. I done exactly the same on my 39 Sedan, which I no longer have.
I used an 8BA out of a 51 Truck, and bought a 59A Cam, used the 39 Transmission, and used 49 Gears in the Trans. The Engine had a 4 inch Crank, .030 Pistons, and a 2 Carb Intake.
Anyway enough of the description of the Engine. Just wanted to let you know in case you didn't, already check into it.
Although the Timming Gear will interchange, make sure you use the 59A one. Reason it has a different pitch to it, and it will draw the Cam to the rear of the Engine.
Should you use the 8BA Gear it will draw the Cam foward, and mess up your Distributor, if useing the Front mount unit with Crab Cap.
You will also need to use the 2 Hole Timming Gear Cover.
Just thought I would let you know as I almost made the mistake, and whenever I hear of someone doing this, I caution them.
