You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Gel point is very dependant on feedstock for the BD.
Here is an exerpt from Wikipedia that attempts to address the question:
"The temperature at which pure (B100) biodiesel starts to gel varies significantly and depends upon the mix of esters and therefore the feedstock oil used to produce the biodiesel. For example, biodiesel produced from low erucic acid varieties of canola seed (RME) starts to gel at approximately −10 °C (14 °F). Biodiesel produced from tallow tends to gel at around +16 °C (68 °F). As of 2006, there are a very limited number of products that will significantly lower the gel point of straight biodiesel. A number of studies have shown that winter operation is possible with biodiesel blended with other fuel oils including #2 low sulfur diesel fuel and #1 diesel / kerosene. The exact blend depends on the operating environment: successful operations have run using a 65% LS #2, 30% K #1, and 5% bio blend. Other areas have run a 70% Low Sulfur #2, 20% Kerosene #1, and 10% bio blend or an 80% K#1, and 20% biodiesel blend. According to the National Biodiesel Board (NBB), B20 (20% biodiesel, 80% petrodiesel) does not need any treatment in addition to what is already taken with petrodiesel."
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
Another thought you can find the Gel Point or better yet the Cloud Point of any BD blend by putting a sample in a glass jar drop a thermometer in it and place it in the freezer compartment of your fridge.
Monitor frequently for signs of clouding record the temp each time you check at the first sign of clouding go back to the last temp as a safe point.
Cloud Point is when the BD starts to form crystals they can plug filters and cause problems so this is the point you should be concerned about. It occurs at a higher temp than Gel Point. Gel Point is the temp when BD will no longer flow.
__________________
You can add chemicals to prevent the gelling. Call the supporter in this forum.... lubrication specialties.com or get ahold of Fabman and he will be able to put you in contact with someone also.
__________________
585,000+ miles on original engine. Goldie 00 F-350
I tapped into the coolant (hot side) before it goes into the heater core, used a tee and some fuel line to make a make shift heater around my fuel fliter. I have been using 50%BD/50% K1 this way for two years. My truck stays in a heated garage at night though. I intend to drop the front tank soon to install a homemade coolant heating loop in it, for both piece of mind and the ability to run B100 year round. I hate worrying about it gelling with the mix. The fuel filter wrap is from Dana Linscott, a guru over at infopop. As stated earlier the freezer test are the only way to know your cloud/gell point. Good luck ,Dave
you can add an anti-gelling additive to the fuel, southern truckers do it all the time when they run north. its cheap and you don't need much, just add it every time you refuel.
__________________
James
2003 F350 XLT Super Duty Crew Cab 7.3L 4x4, 6637, Stancor, 4 inch lift, 35x17 Procomp ATs
2006 Nissan Murano SL AWD
Boilermaker Local 128
I have been thinking of going over to biodiesel now that I found a supplyer in my area but I have heard that the bio is not good for any of the seals in a engin and will cause leaks. I am not to worried about the fuel system because any leaks would be an easy fix but what about the injector orings on a 7.3 di motor?
I would consider replacing injector orings to be a lot of work. What about the fuel pump?
__________________
1994 F350 CC Dually
7.3 DI TURBO DIESEL
5 SPEED
HPX, FPR shimmed, Edge
Intake, Downpipe, Cat delet
