You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
If you put in too much oil the crank will whip it up into a foam which could keep your oil pump from sucking it up and if the foam gets into the hydraulic lifters it can make them collapse. Not Good!:-X23
If you put 5 in mine, the dipstick will say full until you start it and the oil goes into the filter. So i put some in the filter and put a total of 6 in the engine and it reads pretttty close to full.
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
NEW PICS IN MY GALLERY!! :-)
Then theres:
88' F-250 Superduty 351 + c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter. Top speed, 65mph, Go Baby Go!
The newest addition to the Ford family is a 99' Mustang GT 4.6L
I think it depends on what filter you use. When I use a Wix, it takes 6 quarts, but it seems to take over 6 to bring it to full with a motorcraft. Maybe it is my imagination. It is pretty close to 6.
__________________
04 Explorer V6
90F1504X4 extcab 300six M5od
71 Mustang Coupe 302 3 speed
I always put the entire 6 quarts in even though it then reads about 1/2 quart over the top of the full mark. I figure the oil is cooling the lower end so as long as it is not foaming the little extra won't hurt.
INLINE SIX POWER!
300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
"Drive a stick young man! There'll be plenty of time for automatics when you're old and unable."
I put in 6 qts even thought the stick reads overfull. I read somewhere that the dipsticks were either incorrect or confusing on the early models and around '93 or '94 the changed the dipstick.
