How many quarts of oil does 300 six take?
Five or six quarts? It is a 77 300 straight six.
thank you |
Mine takes 6 including 1 for the filter. This is what everything I've read says too.
-------------- [font color="green"]1995 F-150 Supercab XLT longbed 4x4 302 M5OD [/font]31x10.50's [font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job |
I put in 6
Primary rig is: 95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds NEW PICS IN MY GALLERY!! :-) Then theres: 88' F-250 Superduty 351 + c6 95' Mercury Cougar 4.6L V-8 80' E-350 300/6 and a 3 spd column shifter baby. Top speed, 65mph, Go Baby Go! The newest addition to the Ford family is a 99' Mustang GT 4.6L |
i put around 6 in too. i usually have a little left over tho.
My dipstick said over full when I put 6 in mine. Mine likes just a little bit over 5.
-Cope 95 F-150 4x4 4.9L M5OD Front Truetrac Rear Detroit 3.73 Precision Gears Warn Premiums 4" Superlift Superunner |
What happens if you put in too much oil? :-hair
If you put in too much oil the crank will whip it up into a foam which could keep your oil pump from sucking it up and if the foam gets into the hydraulic lifters it can make them collapse. Not Good!:-X23
My Ford manual (1992) says that after an oil and filter change (6 quarts) the dipstick should read over full, just not past the 'F' in FULL.
if you look at it, this will make sense... so I put 6 in and call it good. Matt |
With a filter change, mine uses closer to 7.
I put 5.5 litres which equals 6 quarts when I do a oil and filter change. :-X10
If you put 5 in mine, the dipstick will say full until you start it and the oil goes into the filter. So i put some in the filter and put a total of 6 in the engine and it reads pretttty close to full.
Primary rig is: 95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds NEW PICS IN MY GALLERY!! :-) Then theres: 88' F-250 Superduty 351 + c6 95' Mercury Cougar 4.6L V-8 80' E-350 300/6 and a 3 spd column shifter. Top speed, 65mph, Go Baby Go! The newest addition to the Ford family is a 99' Mustang GT 4.6L |
I think it depends on what filter you use. When I use a Wix, it takes 6 quarts, but it seems to take over 6 to bring it to full with a motorcraft. Maybe it is my imagination. It is pretty close to 6.
I always put the entire 6 quarts in even though it then reads about 1/2 quart over the top of the full mark. I figure the oil is cooling the lower end so as long as it is not foaming the little extra won't hurt.
INLINE SIX POWER!Oo. 300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too! "Drive a stick young man! There'll be plenty of time for automatics when you're old and unable." |
I put in 6 qts even thought the stick reads overfull. I read somewhere that the dipsticks were either incorrect or confusing on the early models and around '93 or '94 the changed the dipstick.
-Jon |
The manual says 6 quarts. I just go by the dipstick with pouring from the 5 gallon bucket.
-=Whittey=- |
