2002 5.4L Engine Swap into 1992 F-150?
Old 11-08-2007, 11:26 AM
E460's Avatar
E460
E460 is offline
I have a complete 5.4 engine and trans out of a 2002 F-250 and would like to install it in a 1992 F-150 SWB that I have. I have the complete wiring harness and ECM from the 5.4 truck. The 1992 has a 320K mile 4.9 that needs retiring.
I have searched this forum and have not found a previous swap of 4.6/5.4 into the older F-150's. Any knowledge, opinions or thoughts about this swap would be appreciated.
P.S. -- I know other engines would be an easier swap, but I already own this low mileage 5.4 and thought I would use it.
Old 11-08-2007, 04:45 PM
Chickenbone's Avatar
Chickenbone
Chickenbone is offline
I just saw a yellow 1976 Ford F-150 in the recent issue of Classic Trucks magazine. It has a 5.4L mod engine and tranny out of a newer pickup truck. Unfortunately they didn't go into specifics on how they got it to work. Perhaps you can contact the mag or the owner of the truck (I think he had a shop do the work) and see how they made it all work. I was considering this same swap (I was going to use a junk yard DOHC 5.4L from a Lincoln Navigator) for my mom's 1986 Crown Victoria project. I still haven't figured out how I will make the computer work. I hope this helps you out.
Chickenbone
Old 11-08-2007, 05:30 PM
E460's Avatar
E460
E460 is offline
Thanks Chickenbone for the info.. I will try to chase that project down!
Any body else got any ideas? I will listen to anything that might help.
Thanks.
Old 11-10-2007, 06:46 PM
Chickenbone
Sorry to bother you E460, but I have some additional information that might help you out. The Yellow 78 Ford pickup that I mentioned is from the January 2008 issue of Classic Trucks magazine and it is owned by Arvel Gatewood. It looks like he contacted The Detail Zone in Deleware for the wiring and tuning of the 5.4L mod engine and tranny. Here is the link for The Detail Zone.
http://www.thedetailzone.com/
Gatewood also contacted Jim Meyer Racing for help with getting the 5.4L engine into the engine bay of the 78. It looks like he welded in an IFS kit from that company. Here is the link for Jim Meyer Racing.
http://www.jimmeyerracing.com/
I hope this brings you a little closer to completing your project.
Chickenbone
Old 11-10-2007, 09:50 PM
E460's Avatar
E460
E460 is offline
Hey Chickenbone,
Thanks again for the info. I will check out these sources. Every little bit helps me get closer to progress on my project.
E460
Old 11-27-2007, 04:27 PM
hunting beater's Avatar
hunting beater
hunting beater is offline
351w/5.4l swap
I am considering installing a 5.4L sohc engine in place of a tired 351W, any info you have on this similar swap would be appreciated. It is a 82 bronco/4spd
Old 11-28-2007, 02:19 PM
Matts72's Avatar
Matts72
Matts72 is offline
You will need an automatic transmission to go with it, bellhousings for the mod motors only exist with C4 transmissions. Summit Racing sells the bellhousings and complete transmissions.
Old 11-28-2007, 06:48 PM
hunting beater
I really prefer to stay with the manual trans, is this possible?
Old 11-28-2007, 07:25 PM
92f150I6's Avatar
92f150I6
92f150I6 is offline
It is if you get the matching trans for the 5.4. like a ZF5 or 6 speed.
Old 11-28-2007, 11:25 PM
Matts72's Avatar
Matts72
Matts72 is offline
Well, the ZFs are significantly larger/longer than any manual tranny offered in the 80s. Modifications to the tunnel are going to be required, as well as a crossmember for the transfer case, and then also your driveshafts. As long as you plan/budget for that, you'll be okay, but its a ton of work.
Old 11-29-2007, 10:45 PM
427SOHC's Avatar
427SOHC
427SOHC is offline
I have mounted a 4.6 liter dohc lincoln engine & tranny in my 79 F100, lot's of work still to do.
I purchased a complete wiring harness diagram from WWW.AHDOL.com for less than 12.00.
I am reusing the entire Lincoln Mark 8 harness but will be splicing in existing lights and other items.
AHDOL has great schematics and email delivery, I have used them on 2 other projects and have been completely satisfied.
94missouriSVT
06-14-2015 12:42 PM
sportsman70
05-30-2015 08:42 AM
dpty22
08-06-2013 12:30 PM
Xx0573
Modular V8 (4.6L, 5.4L)
07-03-2013 11:32 PM
carter2011
16
01-25-2011 05:05 PM
Quick Reply: 2002 5.4L Engine Swap into 1992 F-150?
