Pix of 08 20's on 05 X
on
Well, today was a rainy day which meant the leaves can wait another day!!!
So... I just HAD to see how the new OEM SD 20's would look. So... How do they look? A big thanks to "high1" (Mike) for the inspiration!!!
Like I said in previous posts, all 4 of my 16 inchers are "fused" to the hubs and I'd hate to get stranded with a flat... So as long as I was "PB Blasting" to get the 16's off (to apply a film of anti-seize) I thought I would test fit the 20's. Winters here in upstate NY are harsh (salty) and I'll put the 20's back on this spring.
I've been thinking... Will I need to get a spare tire that matches the diameter of the 20's tires?... You can see that they are a larger diameter.
TILT!!!!
(I like the closed cap... the 08 cap has a larger opening than the 05's lock-outs)
TILT!!!!
TILT!!!!
TILT!!!!
brings up a question...
I have 35s but only a stock spare. When I get a flat, I know that I must put the spare on the front only to keep the rear together. I understand that the tires can be a little different, but how much is the limit?
Recently purchased a G6 Hardtop Conv and it has the donut spare that is about 4-5 inches smaller than the stockers. Would that create a problem on the front (front wheel drive) or not?
Is this OK due to difference in FWD and RWD? This is the first car in 9 years without a matching spare.
on
on
info here
Originally Posted by Monsta
Now where'd you get the spacers again??
https://www.ford-trucks.com/forums/6...05-wheels.html
The spacers are from Fred Goeske... wheelspacer.com
Originally Posted by CommercialNuke
Where are you in upstate NY? I live in the Oswego area and I have seen a rig similar to yours. Is that you?
cdrmotorsports
1999 to 2016 Super Duty
22
09-03-2010 12:02 PM
