2001 Ford F-150 4.6; idle problem
Old 10-23-2007, 07:34 PM
grant5127's Avatar
grant5127
grant5127 is offline
I'm having a strange problem with my 4.6 F-150. The idle is rough and has a rumble to it. The RPM's do not change while this occurs. I have tuned up the engine entirely, and ran a scan on the motor with a detailed program. It checked virtually every variable on the motor, and nothing turned up to be noticeably wrong. Above idle, throttle response is fine and there are no mis-fires. A friend of mine suggested that it may be the ethanol 87 gas, so I ran down the tank and put in 93. This gave me no noticeable change. Can anyone provide some insight?
<!-- / message --><!-- sig -->
Old 10-24-2007, 11:40 AM
KingRanchMan02's Avatar
KingRanchMan02
KingRanchMan02 is offline
When you turn the ignition on, does the CEL illuminate and go off? Is the CEL on when the truck is started. I assume that the scan that you ran checked the truck for stored trouble codes. Good luck!
yasky69
2004 - 2008 F150
08-02-2016 10:19 PM
mainefordman
1997 - 2003 F150
07-11-2015 08:39 AM
mark1963
Modular V8 (4.6L, 5.4L)
05-29-2015 08:22 PM
Crabby144
1997 - 2003 F150
08-29-2014 12:48 PM
Quick Reply: 2001 Ford F-150 4.6; idle problem
