What is a ccv mod?
Old 10-01-2007, 09:33 PM
lazerf250's Avatar
lazerf250
lazerf250 is offline
Question What is a ccv mod?
I keep hearing about this and im not really sure what it is please someone inform me and try not to turn this thread into a B**** fest.....steve
Old 10-01-2007, 09:49 PM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
Well to start please don't single anyONE person out. that is where it gets started. No offense.
Any way the CCV is on the drivers side Valve cover. What is done in the mod is to take the filter off the VC and turn it around to face the rear. You then hook a 3/4" heater hose to the connection and run it out the rear of the truck or into the exhaust. You then remove the aluminum housing on the intake that the CCV was hooked to and replace it with a short piece of 4" exhaust. You will then need to get the new intake boot (if you don't alredy have it). Check my truck pics in my sig for pics. I would poost but there are a few. If this is not clear let me know and I can help more.
The Aluminum housing you remove and replace with exhaust is very restricting and this allows the air to flow better. Post back or PM me if you want.
Old 10-01-2007, 09:52 PM
wreckit72's Avatar
wreckit72
wreckit72 is offline
This mod is to keep oil out of the intercooler on trucks that have added an intercooler.
Old 10-01-2007, 09:59 PM
Neal 97 250
I don't have an intercooler yet. I did it just to reduce restriction on the intake and plan for the future intercooler. Check my pics and browse. I am not on my regular computer so it is hard to find what I need so just dig into mine and ask questions. I will take a pic of the restrictive intake later and post so you can see.
Old 10-01-2007, 10:08 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Old 10-01-2007, 10:14 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
for the the restriction intake and for the hose, like Neal said:
Old 10-01-2007, 10:24 PM
Neal 97 250
Ahhh there you go. To the left is the restriction and to the right is the resolution.
Old 10-02-2007, 06:20 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Nice pictures Jose. I tried tp rep ya but...well you know.
Old 10-02-2007, 08:09 AM
powrstrkr's Avatar
powrstrkr
powrstrkr is offline
Hey, that pic on the right is one I took of the hose Neal sent me a couple months ago to do my mod. Thanks again Neal!!
Old 10-02-2007, 08:22 AM
Neal 97 250
No prob man glad to help. You really don't get a feel for how restrictive the CCV is until you hold it in your hand and loook straight thru it.
Old 10-02-2007, 12:30 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Thanks Cuda, and like Neal said, we are not here for the reps anyway, only to learn alot and to try to help somebody once in a while, within our possibilities .
Old 10-02-2007, 04:02 PM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Green beans are like gettin a pay raise. I'm given em out as much as possible. Especially to the guys (that's you) that give out info pertaining to our rigs.
Old 11-03-2007, 03:07 PM
screech.owl's Avatar
screech.owl
screech.owl is offline
I have noticed that mt truck has blowby out the dipstick tube, will the CCV mod correct this. The way it is now I smell it in the cab.
screech.owl
Old 11-04-2007, 04:47 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
The main purpose of the CCV mod is to eliminate the oil mist from collecting in the intercooler. The oil gets on the rubber boots and they pop off at inconvenient times. Some do it to smooth out the intake pipe.
Yours may be dirty. Remove it and clean out the steelwool inside the CCV box. Be careful not to loose the little orings on the attaching screw. You might want to get new orings before you start in case you find some that are damaged. Use the link in my signature for part #'s.
Search this site for CCV mod, you will find a lot of info. Here's a CCV discussion going on in the NBS forum:
https://www.ford-trucks.com/forums/6...cv-smokin.html
Old 11-04-2007, 07:49 AM
screech.owl
Thumbs up CCV Mods
Thanks Cuda_jim I apprciate your expertise.
Quick Reply: What is a ccv mod?
