Sponsored by: Kumho
leafspring difference
Old Sep 23, 2007 | 07:53 PM
tatonka04's Avatar
tatonka04
Smile leafspring difference
Just wondering what the difference is between the 67-77 and the 78-79 front F250 leafsprings, and can I use a 78/79 front leafspring on my 75?
Thanks
Old Sep 23, 2007 | 08:06 PM
tatonka04's Avatar
tatonka04
I almost forgot, I measured my front springs and they are 3" wide and 53" in length. Would anybody with a 78/79 F250 4x4 mind measuring their springs and post it? Thanks
Old Sep 23, 2007 | 08:08 PM
tatonka04's Avatar
tatonka04
Dohh! I don't know where my head is, but, that is from center of the bolt eye to center of the other eye.
Old Sep 23, 2007 | 08:18 PM
75F350's Avatar
75F350
They are all 53 inches long. The difference is the factory arch. Early trucks had pos. arch springs, and 77.5 to 70 trucks had neg arch units. Length however remained the same.
There are also some differences in hangers, and shackles. The 77.5 to 79 hangers and shackles are longer.
They also fasten too the frame differently. Bolts VS rivets.
Old Sep 23, 2007 | 10:08 PM
tatonka04's Avatar
tatonka04
Ahh, so technically, you could use the 78/79 springs. The reason being is that I found some 4" front lift springs on the Bronco Graveyard site that are cheaper than the 67-77 springs for a 4" lift. Just trying to save a hundred dollars or so. Not trying to cut corners on my project build, just trying to save a buck or two, kinda like geico. LOL Hey 75F350, thanks for the hanger info BTW, I'll get the pics up soon. That's the reason for the front now.
Old Sep 23, 2007 | 10:29 PM
75F350's Avatar
75F350
Cool man, but there is a reason they are cheaper. The 4" lift spring for the 77.5-79 trucks are about the same as the stock 73-77.5 spring. remember the arch thing I was talking about? Later model springs were neg arch, and the early ones were pos arch. That means that if you buy a later model (77.5-79) front 4" spring, you may not gain any lift when used under a 73-77.
Plenty of guys use a factory 73-77 spring under thier 77.5-79 trucks for approx 4 inches of lift., but it does not work the opposite way.
Just do not want you to run right out and buy something that will not lift your truck.
Make sense? Kinda tricky to understand, and unfortunately it all makes sense after you buy the wrong spring.
Man I hate it when that happens.
Old Sep 24, 2007 | 07:27 AM
tatonka04's Avatar
tatonka04
Thanks again. Here is yet another shining example of why I subscribe to this site!
zakt
WTB - Parts & other
Oct 11, 2011 11:53 PM
tbenks
Jan 31, 2010 03:03 PM
351slug
Offroad & 4x4
Dec 17, 2009 08:12 PM
Rob Cuenin
Jul 24, 2006 01:35 AM
SpectreZ91
15
Feb 16, 2006 01:36 PM
